Revision as of 14:41, 6 October 2018 by TK (Talk | contribs)
	if (f)
		char s[81];
		fgets(s, 80, f);
#include "stdafx.h"
#include "Kinematics3Rod.h"
#define sqr(x) ((x)*(x))
// Construction/Destruction
	Act0Center.x = 12;
	Act0Center.y = 0;
	Act0Center.z = 0;
	Act1Center.x = 0;
	Act1Center.y = 12;
	Act1Center.z = 0;
	Act2Center.x = 11;
	Act2Center.y = 3;
	Act2Center.z = 12;
	GeoCorrect(x,y,z,&x,&y,&z);
	return 0;
