Updating KFLOP Firmware
Revision as of 17:02, 27 June 2018 by TK (Talk | contribs)
The error:
indicates that the PC Version of the software that you have
installed doesn't match the firmware software that has been flashed internally into KFLOP.  To update the firmware in KFLOP to match the version of software you are using perform the following steps:
  1. Run KMotion.exe
You may enter the "Version" command on the KMotion Console Screen to verify that the Version of firmware running in KFLOP now matches the Version of software installed on the PC.  To check the Version of Software running on the PC select Help | About in KMotion or Right click the Title bar in KMotionCNC and select About KMotionCNC.
