Revision as of 11:30, 7 April 2018 by TK (Talk | contribs)
  • Show/Hide Controls
  • Change Label/Button Text
  • Change Font/Text Size
  • Bitmap Buttons and Labels
  • JPG, BMP, PNG Bitmaps
  • Toggle Bitmap Labels (LEDs)
  • Custom User Entry Controls
https://youtu.be/w-bKvqXCd0Q
https://youtu.be/VkBhYpyGpNU
https://youtu.be/R44F0_upIoA
  • Label
  • Button
  • MotionButton
  • ToggleButton
  • DROLabel
  • VertBar
  • Radio button
  • Momentary button
  • DualButton
  • Checkbox
  • DualLabel
  • Select ID
  • Type
  • Font
  • BitmapFile1, BitMapFile2
  • Colors
  • Highlight
  • Tool Tip
  • HotKey
  • Var
  • X, Y
  • Width, Height
  • Script
b) Selecting an Action:
  • Show/Hide
  • Move/Resize
  • Undo/Redo
  • Copy/Paste
  • General
Main Window attributes
  • Main Dialog Screen
  • Script File
To Scale a Screen:
  2. Select mode: Screen Scale
Example Original Screen:
Example Scaled up 60%
