KMotionDef
Revision as of 15:07, 11 February 2016 by Moray (Talk | contribs)
KMotionDef.h
The KMotionDef.h, is a C header file which lists all variables and functions available to KFLOP C Programs. The KMotionDef.h file can be located in the  <KMotion Installation Dir >\DSP_KFLOP\ directory.
The Big List
To make already linked variables/functions stand out, the original unedited text has been coloured Blue. As the page is edited and linked, it will revert to normal wiki text colours.
  1. ifndef KMotionDef_h
    #define KMotionDef_h
  1. define KFLOP
    #define C6722
  1. define BOARD "KFLOP"
typedef int BOOL;
  1. ifndef _SIZE_T
    #define _SIZE_T
    typedef unsigned int size_t;
    #endif
  1. ifndef NULL
    #define NULL    0
    #endif
  1. ifndef FALSE
    #define FALSE 0
    #endif
    #ifndef TRUE
    #define TRUE 1
    #endif
    #ifndef PI
    #endif
    #ifndef PI_F
    #define PI_F 3.1415926535f
    #endif
    #ifndef TWO_PI_F
    #endif
    #ifndef PI_2F
    #endif
    #ifndef TWO_PI
    #endif
// standard math funtions
extern float sqrtf (float x);
extern float expf  (float x);
extern float logf  (float x);
extern float log10f(float x);
extern float powf  (float x, float y);
extern float sinf  (float x);
extern float cosf  (float x);
extern float tanf  (float x);
extern float asinf (float x);
extern float acosf (float x);
extern float atanf (float x);
extern float atan2f(float y, float x);
extern float fast_fabsf (float y);
extern double sqrt (double x);
extern double exp  (double x);
extern double log  (double x);
extern double log10(double x);
extern double pow  (double x, double y);
extern double sin  (double x);
extern double cos  (double x);
extern double tan  (double x);
extern double asin (double x);
extern double acos (double x);
extern double atan (double x);
extern double atan2(double y, double x);
extern double fast_fabs (double y);
#define FPGA_ADDR ((volatile unsigned char *)0x91000000)   // Base of FPGA addresses
#define FPGA(X) (FPGA_ADDR[(X)*4+2])
#define FPGA_ADDRW ((volatile unsigned short int *)0x91000000)   // Base of FPGA addresses
#define FPGAW(X) (FPGA_ADDRW[(X)*2+1])
// This structure is set to default every time the program runs UNTIL
// the program image has been FLASHED using the FLASH command
// from then on it will not be cleared, so data that was present at the
// time it was flashed will persist
    typedef struct
    } PERSIST;
extern PERSIST persist;
// data gathering variables
  1. define GATHER_NULL_TYPE 7
    #define GATHER_ADC_TYPE 6
    #define GATHER_DOUBLE_TYPE 5
    #define GATHER_FLOAT_TYPE 4
    #define GATHER_LASTPWM_TYPE 2
    #define GATHER_INT_TYPE 1
    #define GATHER_END_TYPE 0
    void *addr;
} GATHER_VALUE_DEF;
typedef struct
} GATHER;
extern GATHER gather;
  1. define N_CPLX 2048
extern float *input;
          // do the operation
          // 0 = clearbit
          // 1 = setbit
          // 2 = wait for bit low
          // 3 = wait for bit high
          // 4 = beginning of Rapid
          // 5 = end of Rapid
          //    param 0 = bit number
    double a;
    double b;
    double c;
} TRIP_CIRCLE_LINEAR;
    double c;
} TRIP_LINEAR;
typedef struct
    TRIP_CIRCLE_LINEAR X,Y;
    TRIP_LINEAR Z,A,B,C,U,V;
} PARAMETRIC_COEFF;
    int trajectory_mode;
} TRIP_COEFF;
    float d0,d1; // delay values
} IIR;
// Limit Switch Options
typedef struct
}CHAN;
#define ENC_0_3_JP4 0x200
#define ENC_4_7_JP6 0x100
#define NSTEPDIR 8
// Kanalog IO Bit numbers
typedef struct
} SPINDLE;
extern SPINDLE Spindle;
// (returns current time)
// filter coefficients change
int CheckDoneGather();
void StartMove(int ch);
                                                  int NoJerkControlAtStart,
                                                  int NoJerkControlAtEnd,
                                                  int Start,
              int *Nstates);
// Stop profile generation
void StopMotion(CHAN *ch);
// Digital I/O Functions
// Fixed I/O bit definitions
// Virtual I/O bits
// KONNECT AUX PORT FUNCTIONS
// Example:
// Board address is 0,
//  InitAux();
// User Print Routines
// be in the pipeline.
  1. define MAX_STRING 128
 * Dialog Box Command IDs
#define IDOK                1
#define IDCANCEL            2
#define IDABORT             3
#define IDRETRY             4
#define IDIGNORE            5
#define IDYES               6
#define IDNO                7
// Misc routines
// release the lock
void MutexLock(int *mutex);
void MutexUnlock(int *mutex);
// *p = *p | mask;
// *p = *p & mask;
// value.  routine is atomic
// register result = *mutex;
// return result;
    #define KM_SNAP_READ_HI  0xd
    #define KM_SNAP_CLK_ENA 0x09
    // FPGA Registers
// write addresses
// read addresses
void InitRS232(int baud);
  1. endif
