Revision as of 22:21, 18 October 2015 by TK (Talk | contribs)
C Programs provide a powerful and flexible capability to perform almost any sequence of operations within KFLOP.   In most cases after you have tested and tuned all your hardware using the KMotion.exe setup program all the settings and initialization steps required for your system can be placed into an Initialization C Program so that your system can be fully initialized simply by executing the Initialization program.   Using a C Program offers full flexibility to initialize your system however and in whatever order you wish.  In most common cases an existing example can be used with simple modification of values specific to your system.  The KMotion.exe Setup program has some [../Help/ConfigurationScreen/ConfigurationScreen.htm#Utilities automatic capability] to translate the Axes Screen Values that were determined by you during configuration and testing into C Code.
  5. Right Mouse Click "Paste"
  7. Save the file
See the links listed [../Support.html here].
