Revision as of 20:31, 16 October 2015 by BradG (Talk | contribs)
Welcome to our wiki where you can find and share knowledge on Dynomotion's systems.  To begin adding information to this wiki, simply create an account, verify your email, and start editing. To make editing pages easier for everyone, we have installed a visual editor by default.  This visual editor allows you to edit a wiki page much like you would a standard word processing document.  For the seasoned wiki editors, standard MediaWiki editing may also be used.
Creating New Wiki Pages
  • Right-Click with the mouse is a shortcut to insert Links or images.
  • For Spell Correction use Ctrl-Right-Click.
  • To insert a YouTube Video it is required to use an EmbedVideo command such as ¶ {{ #ev }}¶ with xxxxxx changed to the Video ID.
Updating KFLOP Firmware
The error:
  1. Run KMotion.exe
V4.33q
  5. Right Mouse Click "Paste"
  7. Save the file
