Kanalog - Hitachi WJ200 VFD Circuit Question
Druid_ON
Post by Druid_ON » Thu Mar 21, 2019 6:35 pm
Please review my "Proposed Kanalog - Hitachi VFD Circuit" and let me know what changes I should make.
I have attached a copy of the circuit and some VFD info which may apply.
Unfortunately I am a complete neophyte and will need to be spoon fed!
Many thanks for your help and patience!
Keith G
Re: Kanalog - Hitachi WJ200 VFD Circuit Question
Post by TomKerekes » Thu Mar 21, 2019 6:38 pm
Hi Keith,
I don't see any attachments.
Druid_ON
Post by Druid_ON » Thu Mar 21, 2019 6:56 pm
They loaded on my end but with a yellow triangle symbol under status title. Do they load only as doc. files. PDF nor BMP files seem to upload.
Keith
dynomotion
Site Admin
Post by dynomotion » Thu Mar 21, 2019 8:02 pm
You should be able to attach both PDFs as well as BMP files. I'm not sure what the yellow triangle means, do you also get an error message?
Druid_ON
Post by Druid_ON » Thu Mar 21, 2019 8:24 pm
Getting an http error! Super slow loading.
If I drag a BMP file to the message box I get an improper file extension message.
Could I try to post the info on CNCZone but I hate to duplicate a posting.
I will try to post another day on the Dynomotion forum.
Keith G
Druid_ON
Post by Druid_ON » Thu Mar 21, 2019 8:49 pm
I apologize for extra work needed to open zip files but its the only way I could send them.
Keith
WJ200_Instruction Full.7z
(3.74 MiB) Downloaded 263 times
Proposed Kanalog VFDCircuit.7z
(32.18 KiB) Downloaded 248 times
4-16ForwardRunStopandRevers.7z
(185.83 KiB) Downloaded 225 times
4-12 Using Intelligent Input Terminals.7z
(274.45 KiB) Downloaded 242 times
4-10 Intelligent Terminal Listing.7z
(225.24 KiB) Downloaded 245 times
4-8 Sink source of input terminal.7z
(126.83 KiB) Downloaded 248 times
4-6 Control Logic Signal Specs.7z
(258.27 KiB) Downloaded 256 times
Post by TomKerekes » Thu Mar 21, 2019 9:28 pm
Hi Keith,
I hadn't realized *.bmp files weren't allowed. They should be allowed now. But *.pdf and *png are/were supported so we're not sure why you had an issue.
Anyways regarding Proposed Circuit: The Kanalog Switch Outputs can only switch to GND (sink). In your configuration (Source), the pins need to be pulled to +24V to activate. But if you change the Short Bar to Sinking as shown in section 4-8 it should then work. An other option would be to use Kanalog Opto Outputs that can source or sink current.
The Analog connection seems correct.
Druid_ON
Post by Druid_ON » Thu Mar 21, 2019 9:53 pm
Thank you for your speedy reply and clear direction.
I will follow your suggestions and get on with testing my VFD/spindle motor.
Keith
