Interfacing Mitutoyo linear scales
Bernie
Post by Bernie » Fri Jan 11, 2019 1:32 am
I am in the process of converting my Mitutoyo Millstar equipped 2 axis mill. The current setup uses Mitutoyo AT100 series linear encoders.
According to Mitutoyo the encoders put out a 2 volt peak to peak sine wave quadrature signal on 2 wires (plus ground).
There is no mention of a differential signal in the Mitutoyo literature. Will these encoders work when connected directly to KFlop ?
Re: Interfacing Mitutoyo linear scales
Post by TomKerekes » Fri Jan 11, 2019 2:19 am
Hi Bernie,
No those are analog signals not digital incremental quadrature signals.
For compatible encoders types see:
http://dynomotion.com/faq.html#Encoders
There are converter modules that can do a conversion and also interpolate.
Heidenhain is a popular brand, but I think they expect the more common 1Vpp signals.
https://www.heidenhain.com/en_US/produc ... 00-series/
here is one that I believe accepts 2V Mitutoyo signals:
http://www.deva.co.uk/products/single-a ... rpolator-1
