.Net KM_Controller.Compile() error
akorchak
Post by akorchak » Fri Nov 16, 2018 7:22 pm
I'm trying to compile c code file using .Net KM_Controller.Compile() method. I'm getting the following error:
Unhandled Exception: System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
   at System.String..ctor(SByte* value)
   at System.StubHelpers.CSTRMarshaler.ConvertToManaged(IntPtr cstr)
   at KMotion_dotNet.KM_Controller.KM_dotnet_Interop_Compile(IntPtr handle, Int32 boardtype, Int32 threadID, String name, String& outfile, String& error, Int32 _ErrorLength)
The issue doesn't seem to be caused by a particular .c file (tried few of them - same result). The same files are being compiled/executed from KMotionCNC without any issues.
Tried with KMotion versions 4.3.3 and 4.3.4 - same result.
Would appreciate any help. Thanks.
Re: .Net KM_Controller.Compile() error
Post by TomKerekes » Fri Nov 16, 2018 7:37 pm
Hi akorchak,
Did you allocate memory for the return strings?
Can we see your code?
akorchak
Post by akorchak » Fri Nov 16, 2018 10:02 pm
Hi TomKerekes,
Thanks for the response.
No, I did not explicitly allocate memory for the return string (should I?). Here is my code (used "PC VCS Examples\KMotion_dotNet Console" as a template):
_Controller = new KMotion_dotNet.KM_Controller();
string thefile = @"C:\KMotion434\C Programs\ToolChange.c";
String result = _Controller.Compile(4, thefile);
Post by TomKerekes » Sat Nov 17, 2018 2:08 am
Hi akorchak,
Oops you are correct. That routine is rarely used and has several bugs. This will be fixed in the next release.
In the meantime please use CompileAndLoadCoff() instead:
String result = _Controller.CompileAndLoadCoff(4, thefile, false);
