Iam updating my mill to the latest version 4.34 and was wondering if there is a simple way to update KmotionCNC? Or do i need to launch KMCNC from the new install and reconfigure it? This is how i have done it in the past.
Troy
Updating To Latest Version
Re: Updating To Latest Version
Work great.
Just a note, i have custom screens and buttons so had to copy folders 'res' and 'Screens' from directory ...PC VC Examples\KMotionCNC.
Is there any other files that i should copy over for my custom screens? So far all appears ok.
Troy
Work great.
Troy
Hi Troy,
It important to keep track of all files of all types that you have created or modified. If you place the files in a separate directory outside of the KMotion Installation Directory then everything should be specified with a full path which should make upgrading easier.
It probably isn't a good idea to copy those entire directories from the old to the new version. If some file was modified or corrected in the new Version then the file would be reverted to the state of the older version. Probably not likely to be an issue for you in this case. But in general better to only copy files you have created or modified.
Noted.
Thanks again,
Troy
Thanks again,
Troy
