PID Settings for KNozz Board
AmitKumar171
Post by AmitKumar171 » Thu Jun 28, 2018 7:39 am
I am using Knozz board connected with kflop board.
I have connected thermistor Semitec 104GT2 100K ohm thermistor.
When is set the temperature of 200 degrees using m code i am not getting exact temperature. as you said it is 1degree accurate.
How to make it temperature and ADC count graph value accurate. ?
Or i have studied PID temperature control used by arduino board. Proportional Integrative Derivative (PID) Based temperature control is accurate but it is not available with current Knozz Board.
https://www.eurotherm.com/pid-control-made-easy
Above link explains PID based temperature control.
How to implement PID settings into Knozz Board.
Waiting for positive response.
Thank you
AMIT KUMAR
Thank You
AMIT KUMAR
Re: PID Settings for KNozz Board
Post by TomKerekes » Thu Jun 28, 2018 4:50 pm
Hi Amit,
You asked the same question here
