InputGain0 Parameter
I have been adjusting the value of the InputGain0 parameter to make my axis movement accurate, (for example, if I would send a command to move 1 inch, and the actual move was > or < 1 inch, I would adjust the value of the InputGain0 to make the command distance match the actual distance traveled). Is this the right way to do this? If so, what is the relationship between the InputGain0 parameter, encoder counts/revolution, and lead screw pitch?
Re: InputGain0 Parameter
Hi Bill,
I assume you have Servos and Encoders? It is normally simplest to keep the Input and Output Gains at 1.0 or -1.0.
See Also: Axis Resolution
Thanks. I found everything I needed in the Axis Resolution link you provided.
