Speeding up X and Z axis lathe operation
I'm using KFLOP and the Konnect board to control 24V brushed DC motors with encoders in a simple lathe operation. I have the system working, but would like to speed up the entire operation. I have tweaked the individual lines of G code using G01 commands with feed rates, but is it possible to speed up the ENTIRE system in the C program ?
Re: Speeding up X and Z axis lathe operation
Hi Keef,
You would need to explain exactly what you are doing. What is slowing the operation down? What are you doing in the GCode and what are you doing in the C Program? Post a simple GCode Program and your C Program.
