Hi all,
I recently attempted to use geo correction to address the surface roughness of my CNC bed. While it works for Z-axis, I am curious to know if geo correction can be applied to axes other than the Z-axis. The reason for this is that I have been using dual loop control, with my A-axis assigned to measure the Z distance between a probe and the bed surface. The geo correction, which is formatted as (row, col, X, Y, Z), only corrects for Z-axis, and the correction was not applied when the axis was switched to A.
It would be great if such correction can be applied on both Z and A.
Many thanks!!!
Wayne
Exploring Geo Correction Beyond the Z-Axis for CNC Bed Surface Roughness
Re: Exploring Geo Correction Beyond the Z-Axis for CNC Bed Surface Roughness
Hi Wayne,
It's not exactly clear how your machine works or why if you have a bed following mode you would want to make corrections to not follow the bed.
One option might be to have your bed following mode still use the Z axes by re-assigning the Coordinate Motion System. Do you need corrections in both modes? Are the corrections the same?
KinematicsGeppettoExtrude.cpp has Geocorrection for X Y Z and C. Do you know how to recompile the libraries using Visual Studio? See here. You could then make a new class such as KinematicsGEO_XYZA modeled after CKinematicsGeppettoExtrude with everything removed except the Geocorrection functions. Then modify the Geocorrection to use C instead of A. See here on how to make a new Kinematics Class.
Thank you for your detailed response. I appreciate the insights and suggestions you provided. Since I don't have any recompiling experience, this approach might not be straightforward for me. However, it's good to know and will help me rethink my approach.
Many thanks!!!
Many thanks!!!
Hi Wayne,
Thanks for posting back. If you decide that the code needs to be changed we can help with that.
Good luck.
Good luck.
