KFLOP REV 1.3 does not start
Demon-k2008
Hello. We purchased several KFLOP cards. One does not start. All the voltages are present. The LEDs do not turn on after the power supply is connected. There is generation on the processor. There is access to flash memory, but after accessing the memory, everything stops, and the pulses remain only on the generator. Can you provide the firmware that is in the 39VF1602C?
Demon-k2008
Re: KFLOP REV 1.3 does not start
The PC does not see the connection.
Hi Demon,
Sorry you are having problems.
We don’t find it cost effective to repair KFLOPs
We don’t release the image for the Flash memory.
Demon-k2008
Do you know where to apply for the firmware?
No sorry we don’t release that.
If you send us the board we can attempt to reprogram. If that’s the problem then we can return it for shipping cost.
