Spindle load, display analog readings on screen
TFrenken
Post by TFrenken » Thu Feb 13, 2025 9:13 pm
is it possible to display an ADC value on the KMotionCNC screen?
If possible as some kind of bar or percentage, in my case to show spindle load.
Thomas
Re: Spindle load, display analog readings on screen
Post by TomKerekes » Thu Feb 13, 2025 10:47 pm
Hi Thomas,
Yes. You might see the Screen example ShowInstantFeedRate3AxisBar.scr that shows the feed rate as a value and as a Bar Graphic.
The C Program example ShowInstantVelocityDROBar.c updates the Value and the Bar Graphic periodically.
You can read the current value of a Kanalog ADC with ADC(n).
You can use KOGNA_CONVERT_ADC_TO_VOLTS(v) to convert the ADV counts to Volts if needed.
#define CNTS_PER_INCH_X 20000.0
#define CNTS_PER_INCH_Y 20000.0
#define CNTS_PER_INCH_Z 15000.0
#define FULL_BAR_SCALE 50.0
	double Rate,d,x0,dx,y0,dy,z0,dz,t0,t1;
	char s[80];
	for(;;)
		t0=WaitNextTimeSlice();
		x0 = ch0->Dest / CNTS_PER_INCH_X;
		y0 = ch1->Dest / CNTS_PER_INCH_Y;
		z0 = ch2->Dest / CNTS_PER_INCH_Z;
		t1=WaitNextTimeSlice();
		dx = ch0->Dest / CNTS_PER_INCH_X - x0;
		dy = ch1->Dest / CNTS_PER_INCH_Y - y0;
		dz = ch2->Dest / CNTS_PER_INCH_Z - z0;
		d = sqrt(dx*dx + dy*dy + dz*dz);
		Rate = d/(t1-t0)*60.0;
		sprintf(s,"Rate %8.2f ipm\n",Rate);
		// Put it onto the Screen
		DROLabel(1000, 162, s);
		WriteVarFloat(163, Rate/FULL_BAR_SCALE);
		Delay_sec(0.5);
TFrenken
Post by TFrenken » Fri Feb 14, 2025 12:40 pm
thank you for the quick reply and this great solution.
Thomas
