I might have missed the documentation regarding the functionality of the Kogna Reset pin output.
I assume it remains at logic level low until the Kogna is booted and ready to connect ?
The intention is to drive an ssr which is in series with the drives / enable hardware.
Tim
Kogna Reset output pin
Re: Kogna Reset output pin
Hi Tim,
The #Reset pin just pulses low on power up. It would probably be better to use an IO pin such as Bit16 on JP4 that has a pull down resistor that will be guaranteed to be low until set high by you in software after everything is initialized and configured.
