.Net library missing functionalities
dominfo
Post by dominfo » Wed Nov 27, 2024 1:48 pm
[1]
Please can you add the following Property for the next release: KM_Interpreter_SetupParams.DoRapidAsFeeds
I verified and you already implemented the needed interops in KMotion_dotNet_Interop.cpp
Just the .Net property using those is missing ;)
My problem is that it seems that the Hardware FRO is not influencing so much the G0 speed, So I would like to have this functionality.
[2]
Please can you modify the following method KM_Interpreter.SetOrigin(int index, double x, double y, double z, double a, double b, double c)
=> save the Vars file when this SetOrigin method is called.
Remark: I use KMcontroller.CoordMotion.Interpreter.VarsFile to specify the location of this file.
Finally,
I'm actually evaluating a KOGNA (SN150 FYI) + KANALOG for replacing our actual CNC cabinets based on too expensive OMRON CK3E (DeltaTau PowerPMAC Ethercat) and for older customers proposing a retrofit of different DeltaTau PMAC & TurboPMAC (+-10V DAC) we installed in the last 20 years mainly in France and West Europe.
We provide a dedicated custom HMI based in .Net.
That's why I'm heavily testing the different possibilities of your .Net library to adapt our current HMI.
Thanks for your kind support.
Frederic
Re: .Net library missing functionalities
Post by TomKerekes » Tue Dec 03, 2024 1:36 am
Hi Fredric,
Yes we will add. Do you need a patch now?
There is a separate Rapid Rate Override for Rapid moves. See FeedRateRapidOverride.
We will add a SaveVars function
Could you tell us what the PowerPMAC costs?
dominfo
Post by dominfo » Tue Dec 03, 2024 11:06 am
Hello Tom
Thanks for your quick support
Hi Fredric,
Not so urgent. I can wait the next release as a christmas gift ;)
I will test it soon.
Edit: Tested now and working as expected. Thanks.
Perfect !
one PowerPMAC 8 axis Ethercat (OMRON CK3E-1210) costs 2400 euros + taxes (1 euro around 1 dollar) in France.
It's expensive but performance and customisation are outstanding ! (20 years of experience)
Kogna customisations are achieving a very high level according to my currentevaluation !
We will test in January its performance on a 4 axis milling machine that we are actually retrofitting.
In PowerPMAC, "Gcode interpreter + Trajectory planner + Lookahead" are embedded.
=> We transfer directly the Gcode file to the PowerPMAC.
I will evaluate the possible latency due to the "GCode interpreter + Trajectory planner" being hosted in the PC.
Our customers are using Gcode programs (3D milling) with very small segments at a high rate.
The machine should not wait for the coordinated motions coming from this software chain "Gcode interpreter + Trajectory planner".
I hope that the lookahead feature will be fast enough for that.
Frederic
Post by TomKerekes » Tue Dec 03, 2024 7:24 pm
Hi Fredric,
Thanks for the info.
We think KMotion handles small segments at a high rate very well. Let us know if we can help with any issues.
Post by TomKerekes » Sat Dec 07, 2024 1:47 am
Here is an article on how the Trajectory planner handles small segments. The test case is a 90degree 1 inch radius arc made of 30 segments with 3 degree direction changes executed at 5.5 inches/sec (330ipm). To smooth the path the Trajectory planner uses segments with 0.5 degree angle changes (180 segments). The arc is traversed in 0.08secs resulting in 625 segments/sec.
We've never had a segment processing rate issue with KFLOP and Kogna has a significantly higher communication rate and processing rate.
I see the PowerPMAC 8 axis Ethercat (OMRON CK3E-1210) claims 10,000 blocks/sec. But I'm not sure what that even means with a sample cycle of 250us?
Here is an a example of fairly rapid and accurate milling with a high segment rate. Bob Garrish was actually the User to submit the TESTCURVEOFTERROR3DEG.NC GCode used in the article.
dominfo
Post by dominfo » Tue Dec 10, 2024 12:51 pm
Hi
The integrated "Gcode interpreter+trajectory planner" is able to treat 10000 block/sec; a Gcode line like G1 X10 F150 represents 3 blocks.
The 250us is the Ethercat "synch clock" between the master (PowerPMAC) and the multiple slaves (servo drives).
Frederic
Post by TomKerekes » Wed Dec 11, 2024 11:03 pm
Hi Frederic,
I tested KMotionCNC's Interpreter and Trajectory planner. A GCode file 1 million lines long (mostly 2 blocks/line XnnZnn) with my older i7 PC executed in 8 seconds. That's over 200,000 blocks/sec. :)
