I've been using my rotary axis and it's working pretty well. However, it's very manual to zero the Z Axis so I tried to write a couple of C programs. One to move to the X,Y,Z location of the rotary axis at the start and one to move to a tool change location, then to the touch plate to rezero the Z (bed level) and then back to the rotary axis Z zero. Most of the code works fine except when I zero the Z with the touch plate (bed level) and then try to move to the rotary Z zero. I can't simply move to a location (axis destination) because the length of the tool varies.
After i go through the touch plate routine I zero the Z DRO. How can I simply move up 2.5" to the rotary Z zero location and then reset the DRO to the new Z zero location? Seems like this should be pretty simple but I haven't had any luck.
Jack
Zeroing a Rotary Axis
- Rotary Tool Change.c
- (2.44 KiB) Downloaded 586 times
- Rotary Fixture X and Z zero.c
- (2.13 KiB) Downloaded 610 times
Re: Zeroing a Rotary Axis
Hi Jack,
I'm not sure I understand, but you can request the axis resolution (in counts/inch) then multiply 2.5 inches by the resolution and do a relative move of that many counts.
See the \C Programs\ToolTableSetDebug.c example for how to get axis resolution.
Thanks for the info. I got my rotary axis and positioning working. The ToolTableSetDebug.c helped a lot.
I did have trouble trying to do:
GetMachine(&Machinez);
I finally realized I needed to use:
GetMachine(&Machinex, &Machiney, &Machinez, &Machinea, &Machineb, &Machinec);
My program is working but I was wondering is there a simple way to just get the Z axis position vs getting all of the axis?
Jack
Jack
Hi Jack,
No there isn't. Why would you want to get only one when you can get all for the same price.I was wondering is there a simple way to just get the Z axis position vs getting all of the axis?
