KAnalog JP10 RS232 connector pins
georgep
Post by georgep » Sat Oct 19, 2024 7:02 pm
I'm implementing a remote control connected to Kanalog's RS232, which is tested and working. To avoid extra cabling, I’d like to supply 12V power to the remote using a spare pin on the RJ12 cable.
The manual appears to show JP10 pins 2, 5, and 6 as 'Not Connected.' Can someone confirm if this is correct? I’d like to use one of these pins to power the remote without risking damage to the Kanalog. I’m not too worried if this isn't following standard RS232 conventions since this is a custom setup.
George
