Log Bit Status
kizilkaya
Log Bit Status
Post by kizilkaya » Mon May 06, 2024 4:50 pm
Hello Dear TOM
I added a checkbox in "ToolSetupTPPage". When it is active, I want to print the status of virtual bits between 1024-1120 to the "Z:\\OILOG.bin" file once a second as 96-bit data, for example: If bits 1024, 1029,1120 are active, they are 96-bit. The data should output like out.txt:
So the first bit represents 1024, the 2nd bit represents 1025, the 3rd bit represents 1026.... 96 bits represent 1024.
Note : I could not edit the data from the GetVirtualBits command so that the first bit represents 1024 and the last bit represents 1120.
Can you help me with the code, good work.
btn.txt
(50 Bytes) Downloaded 1624 times
out.txt
(142 Bytes) Downloaded 1716 times
Re: Log Bit Status
Post by TomKerekes » Mon May 06, 2024 5:18 pm
Hi kilzilkaya,
It would be nice if you explained what you are trying to accomplish. If you need these bits in another Windows App it would be better to have the app read them directly.
You might look at or use the function:
bool CScreen::ReadBitCached(int bit)
You can get the Virtual bits individually by calling the function with bit from 0 - 95
kizilkaya
Re: Log Bit Status
Post by kizilkaya » Wed Jul 03, 2024 11:41 am
Dear Tom
Is it possible to write two examples?
Example 1) Reading 1024 bit status?
Example 2)1025 setbit ?
Thank you for your attention.
Re: Log Bit Status
Post by TomKerekes » Wed Jul 03, 2024 8:57 pm
bool bit = TheFrame->GCodeDlg.Screen.ReadBitCached(1024);
TheFrame->KMotionDLL->WriteLine("SetBit1025");
kizilkaya
Re: Log Bit Status
Post by kizilkaya » Thu Jul 04, 2024 1:15 am
Thank you very much TOM, you are best :)
