Macro programs in KMotionCNC
Alexanders
Post by Alexanders » Fri May 03, 2024 12:53 pm
Does KMotionCNC support macro programming on Macro B ?
I am trying to apply operators such as IF, WHILE .... However, KMotionCNC produces various syntax-related errors.
Re: Macro programs in KMotionCNC
Post by TomKerekes » Fri May 03, 2024 7:41 pm
Hi Alexanders,
No 'IF' and 'WHILE' aren't supported. But the similar functionality can be achieved with looping subroutine calls. See the example SubroutineWithConditionals.ngc shown below:
G20
#100 = 5
(examples of logical operations)
(result is 1 if condition is true)
(result is 0 if condition is false)
#101 = [#100 >  5]
#102 = [#100 >= 5]
#103 = [#100 <  5]
#104 = [#100 <= 5]
#105 = [#100 =  5]
#106 = [#100 <> 5]
(subroutine call can be looped a number of times)
(the L or Q word may be used to specify the count)
(if neither L or Q is specified a count of 1 is used)
(if the count is 0 the subroutine will not be called at all)
M98 P1 L3  (example using L to specify the loop count)
M98 P1 Q3  (example using Q to specify the loop count)
M98 P1 L#100  (example using a variable loop count)
M98 P1 L[5 > 4]  (example using a conditional as a loop count)
M2
O1
#200 = [#200+1]
M99
