Kernel speed
Dennis Johnson
Kernel speed
Post by Dennis Johnson » Fri Nov 24, 2023 4:33 pm
I'm working on my second retrofit using kflop/kanalog. My first one makes obvious stepper sounds even though it's fitted with servo's. It also makes a screaming sound when the drives are in position for more than a few seconds.
I have 3 questions:
1. What should the "kernel speed " in machb3 be set to?
2. Is there a connection I should make to the "p-con" pin on the yaskawa drives to the kanalog board to put them to rest after they're in position?
3. Is there a better choice other than mach 3 for my new lathe retrofit?
Re: Kernel speed
Post by TomKerekes » Sat Nov 25, 2023 7:42 pm
Hi Dennis,
Seems like tuning issues. Post some Step Response Screen plots. Include some with Move Size 0 while making the "screaming sound"
That shouldn't matter the Mach3 kernel is not used. Set to a large value.
No I don't think so.
Yes our Free KMotionCNC
