Hello Tom
I have a Gcode which is triggering an error from KMotion, just after being started by my .Net app:
=> Invalid buffer times in Trajectory Planner
The program is inspired from polygon.ngc (a topic we discussed before)
what could be the reason of this error ?
Frederic
**** Edit ****
I'm using the x64 version
Gcode issue in trajectory planner
- program.ngc
- (2.94 KiB) Downloaded 1205 times
Re: Gcode issue in trajectory planner
Hi Frederic,
It runs ok in KMotionCNC Debug 64-bit. Does other GCode run ok from your App? You might set KMotionCNC's Trajectory Planner values to the same as your .NET App to see if it has a problem.
Hello Tom
I confirm that it works with KMotionCNC 64 bits with same trajectory planner settings, same with the GCode interface of KMotion in 64 bits.
Is it something related to the Kmotion_dotnet 64 bits ?
When compiling my .net app towards the Kmotion_dotnet dll in 32 bits, I don't have the issue.
Frederic
Frederic
Hello Tom
Sorry for late replies.
Yes other Gcode runs with the 64 bit version if not using a programming style like "polygon.ngc" ie the O103 subprogram on my example.
Frederic
Frederic
Hi Frederic,
I can't duplicate the problem. It runs oK in the 64-bit Release code of the Version 5.3.0 Dynomotion VB .NET example.
