Running a .exe from M Codes
PBandJacob
Hello!
I'm able to call an MCode set to run a PC application. I want to run this application whenever the device powers up, but I don't want it to run under other circumstances. Right now I have a "handler" .exe that checks to see if the other .exe is running. If the other .exe isn't running, it calls it and exits. If it is running it prints out a status message and exits. When I run the .exe's from the command line or by clicking on their icons, they behave as expected. When I try to call them as an MCode, I either get a "timeout waiting on action" message or I get an error stating "Error Executing PC Program: C:\\pathtofile\\, Return code = -1 Abort?"
I know that some processes when called generate multiple instances of themselves in the tasklist. I haven't had any trouble trying to call these programs multiple times in other cases, just when calling it from KMotionCNC's M codes.
Is the problem that I'm running an executable that calls another executable?
Any help is welcome.
Re: Running a .exe from M Codes
The issue might be that KMotionCNC launches the App with a hidden window. Unless your App changes to be shown then you won't see your Message Box.
Another workaround is to have KMotionCNC launch a .bat file (hidden) which then starts your App in a separate Process.
You might see this Thread.
PBandJacob
I switched it to a .bat file for execution and now it has:
C:\\Users\\pathtofile
Return code = 1
Abort?"
It got that same error when I put it in the KMotion CNC start up action.
Return code = 1
Abort?"
Did you use the start command to start the App as a separate process?
Is the pathtofile correct? Looks like you have double slashes?
post your batch file.
PBandJacob
So the .bat file is already on the Desktop so that ends up being the path it opens to initially so I'm able to call the .exe which is also on the Desktop
I made the .exe files in Python and used pyinstaller to turn the scripts into .exe files.
The contents of the .bat file are just: testhandler.exe
In Prog Start I selected "Execute PC" from the drop down menu.
I had to convert the attachments to .txt files because the .py extension wasn't supported.
- testhandler.txt
- (984 Bytes) Downloaded 330 times
- test.txt
- (231 Bytes) Downloaded 328 times
You didn't use the 'start' command in the batch file to spawn your App as a separate process.
But anyway your App doesn't seem to display anything on the screen so would probably be simpler running hidden (no batch file).
Your App returns with exit code -1. KMotionCNC considers return code of 0 for success and non-zero for failure. Try changing your App to 0 exit codes.
I think a batch file will return non-success if it calls an App that return non-success. btw using the 'start' command is different as the batch file will return to KMotionCNC before the App begins execution in a new process.
Also shouldn't this be a 1 not 2?
if tasks.count("testhandler.exe") > 2Regards,
PBandJacob
For some reason two processes were generated every time it ran. I'm looking into pyinstaller to see if there's some configuration I can use to have it only generate one process in Windows tasklist
PBandJacob
Thank you so much Tom!
I ended up doing this for the .bat file which did exactly what I wanted:
start /d C:\pathtodesktop\ /b testhandler.exe
On the Python end, using exit code 0 also worked and I was able to just run the .exe file without a .bat and had no error messages pop up.
PBandJacob
On an unrelated note, sorry about not responding on some previous posts I've made. There was some hiccup with my network where I could make initial posts but not reply to them. Thankfully it seems like that is fixed now.
