I'm currently using persist variables to move backlash amount and direction variables about my code for various reasons (such as being able to keep BL amount and direction after an axis has been .enabled and when my app is started and stopped. My code appears to be working but I'd like some clarity on the types I should be using and if I'm casting them correctly or just 'lucking out'.
As kept in the KFlop, should ch->Backlash be a float and ch->BacklashDirection be an int?
I'm currently using the following code to copy the values from the KFlop into the persist variables, which seems to work, but doesn't seem like it should.....
float Axis0_Backlash;
float Axis0_BacklashDirection;
Axis0_BacklashDirection=ch0->BacklashDirection;
Axis0_Backlash=ch0->Backlash;
persist.UserData[GPV__AXIS_0_BACKLASH] = *(int *) & Axis0_Backlash;
persist.UserData[GPV__AXIS_0_BACKLASHDIRECTION] = *(int *) & Axis0_BacklashDirection;
.....and this code to copy the values from the persist variables back into the KFlop......
Axis0_Backlash = *(float *) &persist.UserData[GPV__AXIS_0_BACKLASH];
Axis0_BacklashDirection = *(float *) &persist.UserData[GPV__AXIS_0_BACKLASHDIRECTION];
ch0->Backlash=Axis0_Backlash;
ch0->BacklashDirection=Axis0_BacklashDirection;
I feel like I've got 'two wrongs making a right' somewhere here. I'd appreciate any suggestions.
Backlash amount/direction variable type and persistence...
SamMarrocco
Re: Backlash amount/direction variable type and persistence...
H Sam,
What you have is not exactly logical but should work. This line:
converts the small integer to floating point format which can be represented exactly in floating point.
The value is then saved as a float and retrieved as a float.
The float is then reconverted to an integer here:
yes. For definitions see KMotion_def.hAs kept in the KFlop, should ch->Backlash be a float and ch->BacklashDirection be an int?
int BacklashMode; // Type of correction: Currently only BACKLASH_OFF, BACKLASH_LINEAR
float BacklashAmount; // Amount of Backlash to be applied
float BacklashRate; // Rate Backlash shoule be applied, counts/sec
int BacklashDirection; // Last non zero direction moved
float PrevBacklashDest; // Prev Destination where backlash was determined to allow small hysteresis
float Backlash; // current amount of compensation being applied
Axis0_BacklashDirection=ch0->BacklashDirection;The value is then saved as a float and retrieved as a float.
ch0->BacklashDirection=Axis0_BacklashDirection;Regards,
