Kanalog jp13
Rasta
Kanalog jp13
Post by Rasta » Thu Sep 16, 2021 8:34 am
Hi;
I’m trying to turn on a AC SSR , directly from the Kanalog JP 13 Opto_0_plus ,and Opto_0_neg , the SSR
Dc input is from 3v to 30vdc .
Can you please tell me is it’s possible? And if so , what is the voltage that I should get between Opto_0_plus and Opto_0_neg..
Thank you
Mariano
Re: Kanalog jp13
Post by TomKerekes » Thu Sep 16, 2021 4:09 pm
Mariano,
Opto Outputs do not supply any Voltage. They operate like a switch. You will need some voltage source (ie 24V supply). Then wire it as a circuit as you would with a battery, light bulb, and switch.
Rasta
Re: Kanalog jp13
Post by Rasta » Thu Sep 16, 2021 11:08 pm
ThanksTom , for the prompt answer
Does it means that for voltage source I can use the Kanalog 5v and ground pins to supply the voltage source? If so please can you please provide connection guidance?
Mariano
Re: Kanalog jp13
Post by TomKerekes » Thu Sep 16, 2021 11:35 pm
Hi Mariano,
Yes. Connect:
+5V to an Opto Output +
Opto Output - to the SSR Control Input +
SSR Control Input - to KFLOP GND
Rasta
Re: Kanalog jp13
Post by Rasta » Fri Sep 17, 2021 10:21 pm
Thank you Tom,
You are a Champ!
Mariano
