i am using these drives
http://servosystems.com/pdf/amc/30a20ac.pdf
simple 2 wire DC brushed servos
not sure if i need something like this with 2 DAC outputs?
ch1->OutputChan0=1; //positive pin on drive
ch1->OutputChan1=2; //negative pin on drive
or wire ch1->OutputChan0=1; to positive pin and negative pin to kanalog board ground?
AMC drive use 2 DAC for output? DC motor
Re: AMC drive use 2 DAC for output? DC motor
Hi turbothis,
No, you only need one DAC since the Drive accepts +/- 10V. You might do this simple test and this with a DAC (step 2).
ok i got the Y axis moving safely!
thanks a ton once again for the support
trying to figure out the counts per inch
i think 2000 on the servo encoder
x4 for quadrature
2-1 reduction on the pulley
.200 screw
80,000?
i do this and with the test indicator moving .500" i am about .010" short
if i punch in 81250 i am about right on .500 move and reading
x4 for quadrature
.200 screw
80,000?
If the screw was 5mm pitch it should be 81280 counts/inch
