Toggle Button and low high bit
GabrielR922
Post by GabrielR922 » Thu Jul 08, 2021 11:58 pm
Is there a way without a c program to make a toggle button ?
When the button is pressed certain bit goes high if it was low or goes low if it was high.
Thanks.
Re: Toggle Button and low high bit
Post by TomKerekes » Fri Jul 09, 2021 4:44 pm
Yes see Video
GabrielR922
Post by GabrielR922 » Sat Jul 10, 2021 12:25 am
Thanks Tom, that was what I needed.
Rasta
Post by Rasta » Wed Sep 08, 2021 12:38 am
HI Tom;
I have followed the directions in the Toggle button video , and yes I can modify the buttons , but after I exit KmotionCnc , and fire
it back again ,the buttons or anything that I have done is no updated , can you please tell me what im doing wrong?
Mariano
Post by TomKerekes » Wed Sep 08, 2021 3:42 pm
Hi Mariano,
Are you writing the modified Screen Script?
Rasta
Post by Rasta » Thu Sep 09, 2021 12:40 am
Yes , I have renamed the screen Wire Edm .scr
On the main tab I select the screen script Wire Edm.scr
Then go back to the Control Select screen and to just try it , modify the 46 Momentarily button , by changing its name to Main Pump, then I observed that the name Main Pump, appears on the button now . After that I closed the screen editor , and
Also closed the Kmotion CNC ,
Then fire up Kmotion CNC and observed that the button that I have modified previously ,is back to its original setting ( 46 Momentarily ) instead of Main Pump,
Please help
Mariano
Rasta
Post by Rasta » Thu Sep 09, 2021 12:48 am
Please disregard my last message
I found the problem ,
I did not Write the script , silly me
Thank you for your help
Mariano
