Homing in positive direction and assign value
Mateusz
Post by Mateusz » Fri Jun 11, 2021 8:01 pm
On the machine I have already mounted Home switches on very end of axis in positive direction, machine homing in positive direction and should assign a value lets say equal to work range.
I can not understand what I'm doing wrong in modified code below, I replaced a Zero(axis) with Pos(axis)=variable command but It just wont compile.
Mateusz
SimpleHomeIndexFunctionTest.c
(841 Bytes) Downloaded 165 times
SimpleHomeIndexFunction.c
(2.23 KiB) Downloaded 194 times
Re: Homing in positive direction and assign value
Post by TomKerekes » Fri Jun 11, 2021 8:12 pm
Instead of:
	Pos(axis)=homepos;  //Assign declared position
The syntax is:
	chan[axis].Position=homepos;  //Assign declared position
