SpindleOnCWJogDir.c not working :'(
I desperatly need your help, I have been trying for many hours to run my spindle without success :
*Step Dir output
*Channel 4
*Encoder 2500ppr
*Jogging is working in the console, VFD receives properly the pulses
*M3 set with SpindleOnCWJogDir.c
If I type M3 S500 in KMotionCNC the VFD will not receive anything, in the Kmotion console the printf("Jogging Spindle %f counts/sec\n",speed * FACTOR); would show 0, so I guess for an unknown (yet) reason the speed command does pass through.
Any idea what I did wrong in my setup?
Cordially
Francois
*Step Dir output
*Channel 4
*Encoder 2500ppr
Cordially
Francois
Re: SpindleOnCWJogDir.c not working :'(
Hi Francois,
What persist Var is the S Action configured to pass the Speed to the C program in? What persist Var is the C program expecting the Speed to be in?
Thanks for your help, I am bit lost (not really/at all a programmer), here is the C program used (fully original from installation) :
#define SPINDLEAXIS 4
#define FACTOR (2048/60.0) //1000 counts/sec / 100 counts/rev = 1 RPS = 60 RPM
#define SPINDLECW_BIT 154
#define SPINDLECCW_BIT 155
#define SPEEDVAR 99
#define STATEVAR 98
#define KMVAR 1
float speed = *(float *)&persist.UserData[SPEEDVAR]; // value stored is actually a float
float LastState = persist.UserData[STATEVAR]; // get last state
if (LastState==-1)
// if spindle was CCW now we want CW
// spin down
ClearBit(SPINDLECW_BIT);
ClearBit(SPINDLECCW_BIT);
Jog(SPINDLEAXIS,0);
// turn spindle on CW and ramp to new speed
SetBit(SPINDLECW_BIT);
persist.UserData[STATEVAR] = 1; // remember we are CW
In KMotionCNC, the variable set is 1.
Cordially
Francois
#define SPEEDVAR 99
#define STATEVAR 98
#define KMVAR 1
if (LastState==-1)
// spin down
Jog(SPINDLEAXIS,0);
Cordially
Francois
I found a nice page : https://dynomotion.com/Help/KMotionCNC/ ... Params.htm
By reading it and checking again the code, I would think that KMVAR is not even needed, but SPEEDVAR should be 1, am I correct?
There are 4 actions and programs involved with the Spindle. M3, M4, M5 and S. For OnCW, OnCCW, Off, and Speed respectively.
The program you posted is for OnCW (M3) which doesn't pass the Speed. What Program do you have assigned to the S Action in KMotionCNC | Tool Setup | M0-M30 ? Post your 4 Programs and any included files.
You might also read this.
Here are the different codes, with the threads and variable as in the manual :
thread 2 for all
variable 1 for M3, M4, M5
variable 113 for S
M3, M4, M5 do not need variable then (could be -1) ? And variable for S should be 1?
M3
M4
M5
S
thread 2 for all
variable 113 for S
M3
#define FACTOR (-500.0/2007) // -500 counts = 2007 RPM
// desired speed is passed in variable 1
// save in user variable 99 the last speed setting
// save in user variable 98 whether it was off, CW, or CCW (0,1,-1)
// save in user variable 97 the last desired speed
float speed = *(float *)&persist.UserData[97]; // value stored is actually a float
float LastSpeed = *(float *)&persist.UserData[99]; // get last speed setting
float LastState = persist.UserData[98]; // get last state
if (LastState==-1)
// spin down
ClearBit(154);
ClearBit(155);
LastSpeed = 0.0;
Jog(SPINDLEAXIS,0);
SetBit(154);
if (LastSpeed != speed)
LastSpeed = speed;
*(float *)&persist.UserData[99] = LastSpeed; // save the last speed
persist.UserData[98] = 1; // remember we are CW
M4
#define SPEEDVAR 99
#define STATEVAR 98
#define KMVAR 1
if (LastState==1)
// if spindle was CW now we want CCW
// spin down
Jog(SPINDLEAXIS,0);
// turn spindle on CCW and ramp to new speed
SetBit(SPINDLECCW_BIT);
Jog(SPINDLEAXIS,-speed * FACTOR);
persist.UserData[STATEVAR] = -1; // remember we are CCW
M5
#define SPEEDVAR 99
#define STATEVAR 98
#define KMVAR 1
// spin down
Jog(SPINDLEAXIS,0);
printf("Jogging Spindle Stop\n");
persist.UserData[STATEVAR] = 0; // remember we are Off
include "KMotionDef.h"
#define SPEEDVAR 99
#define STATEVAR 98
#define KMVAR 1
float speed = *(float *)&persist.UserData[KMVAR]; // value stored is actually a float
persist.UserData[SPEEDVAR] = persist.UserData[KMVAR]; // Always save the last desired speed
if (LastState==0)
// if spindle is off and User Changes the speed
// just save the desired speed
return 0;
Jog(SPINDLEAXIS,LastState * speed * FACTOR);
Correct.M3, M4, M5 do not need variable then (could be -1) ? And variable for S should be 1?
Thanks, it works !
I have now another concern, there are some offsets between desired speed, VFD monitored frequency, and Kmotion monitored speed, let me give some examples :
Gcode / Spindle speed in KMotionCNC / Command Frequency of the VFD / Monitored VFD frequency/ Speed according VFD
M3 S300 / around 261rpm / 9.99Hz / 10.02Hz / 299rpm
M3 S750 / around 695rpm / 25.11Hz / 25.09Hz / 752rpm
M3 S1500 / around 1413rpm / 49.98Hz / 50Hz / 1499rpm
M3 S3000 / around 2910rpm / 100Hz / 100.14Hz / 2999rpm
There are big variations of speed on KmontionCNC, +/-10rpm which does not seem so normal to me (also at 0 speed), encoder is 2500ppr, all cables shielded and grounded.
Any idea of the problem?
Cordially
Francois
Thanks, it works !
Cordially
Francois
Hi Francois,
What kind of encoder do you have? Differential? Single ended? How/where is it connected?
Check if it is counting correctly. Zero the Position and mark the physical spindle position. Then move/run the Spindle. Then move the Spindle back to the same position. Does the Position read within several counts of a multiple of 10000 counts?
This is a single ended encoder, it is connected in parallel to the VFD feedback card and to the IO38-39-40 (IO36-37 being used to step-dir the VFD). But it was before connected to the ouput of the VFD feedback card with the same result.
I already checked roughly if it was counting properly and it was (with the VFD pulse counting), but I will perform tomorrow a more accurate test with Kmotion, should I use the position from the status?
The fact that there is a lot of oscillations even with spindle stops makes me think about noise issue.
Cordially
Francois
Cordially
Francois
