Hello.
I try to change in the viewer the tool image dimension, by changing the "tool scale" parameter but nothing happens.
Only when i have not assign a tool image it works. When i assign an image to the tool then it does not change the dimension.
What im doing wrong here?
I'm using the 435f version.
Regards.
Tool scale
Re: Tool scale
Well the idea is that if you have a model of a specific tool it should be the actual size of the tool. That way you can select different models for different tools and they will show the correct size regardless of any scaling. It should be fairly easy to scale any model with some free CAD Tool like Blender.
