Plasma cutter tool offset
cnc_freak
Contact:
Post by cnc_freak » Wed Mar 31, 2021 6:49 am
Hello.
In a plasma cutter i try to use G42 in order to compensate the arc diameter. The problem is that when i try to cut rectangle/orthogonal pieces i get the message "Concave corner with cutter radius comp".Is there a way to workarount this issue, because i can't change the cutting part with radius on the corners.
Regards.
Re: Plasma cutter tool offset
Post by TomKerekes » Wed Mar 31, 2021 4:34 pm
No, there isn't a way to go around an "inside corner" with a round tool without gouging. You will need to add arcs to the corners.
cnc_freak
Contact:
Post by cnc_freak » Wed Mar 31, 2021 5:22 pm
Its an "outside corner" i want to go around. Is there a way to define a square tool?
Post by TomKerekes » Wed Mar 31, 2021 5:29 pm
Then you should not get that error. Maybe your entry move into radius compensation. See here.
Post the GCode and your Tool Table Settings for the Tool.
What Version are you running?
No :)
cnc_freak
Contact:
Post by cnc_freak » Wed Mar 31, 2021 7:43 pm
Here are two gcode files. Rename them to *.ngc and the default.txt is the tool file, rename it to *.tbl
I use 435d version.
Regards.
Default.txt
(481 Bytes) Downloaded 156 times
00000102.txt
(772 Bytes) Downloaded 185 times
00000101.txt
(513 Bytes) Downloaded 180 times
Post by TomKerekes » Wed Mar 31, 2021 11:07 pm
I think it depends on where the tool is when you start the Job. You don't have a controlled entry move into radius compensation.
The GCode turns on radius compensation and moves to a starting point of X=672 Y=7 and moves upward.
If the tool begins on the Left of that point it is ok:
If on the Right there is a gouge
