Is it possible to enter a distance move from the console to check counts per inch?
Scott
Console Screen commands
Re: Console Screen commands
you could certainly use the "move" command. If you think it should be 100 cts/inch, send that and see if it actually is. why not just use the MDI in kmotion CNC?
I think the "linear" command can command the machine to move in actual units with the trajectory planner but I could be wrong
Got it, thanks for your help.
Scott
Scott
