Is there a C code equivalent for the script command CheckThread?
Something similar to ThreadExecuting(int thread) in the C# file KM_Controller.cs.
I don't want other threads (homing, etc.) to run unless thread 1 (initialization thread with forever loop) is running.
CheckThread in C?
HowHardCanItBe
Re: CheckThread in C?
Check the variable ThreadActive.
A test for bit 1 would be:
extern volatile int ThreadActive; // one bit for each thread
if (CurrentThread & 2)
// Thread 1 is running
}Regards,
HowHardCanItBe
Awesome. I had forgotten all about bitwise operators.
Shouldn't it be (instead of CurrentThread);
if (ThreadActive & 2){}- TomKerekes
