Hi Tom and Sascha,
I am new to this forum so just trying to work out its functionality and etiquette.
I have some questions after doing some reading and tinkering.
I have Kflop connected and have worked out the basics of the screen editor. Two issues are unresolved for me at the minute
1: How can I run a program slowly. I have turned feed to a minimum but program races to the end?
2: GViewer is not displaying the path only the tool; movement (It is showing in the KMotion CNC 3x DRO screen though)?
regards,
Vic
GCode Viewer
Re: GCode Viewer
Hi Vic,
I don't understand what you mean. You might Single Step.1: How can I run a program slowly. I have turned feed to a minimum but program races to the end?
If a custom screen is in use you should close the separate GCode Viewer Screen and use the GCode Viewer Control on the main screen.2: GViewer is not displaying the path only the tool; movement (It is showing in the KMotion CNC 3x DRO screen though)?
