Connecting Two Kflops Together
cyprian21
Post by cyprian21 » Sat Jul 18, 2020 10:20 pm
Hi there,
I searched the forums but did not see if anyone already asked this.
My application will require more than 8 axis. Can you cluster two Kflop boards together so that you can control up to 16 axis?
If yes, is there any documentation on this topic?
Thank you kindly,
Cyprian
Re: Connecting Two Kflops Together
Post by TomKerekes » Sun Jul 19, 2020 8:06 pm
Hi Cyprian,
Multiple KFLOPs can be added to a PC. Your App can send commands to each board independently. But the axes across multiple boards will not be real time synchronized unless you add some sort of real-time communication or trigger signal between the KFLOPs. What are the requirements of your application? See here.
