Global Variables
AlMoutaz_Billah
Global Variables
Post by AlMoutaz_Billah » Wed Apr 29, 2020 12:18 pm
Maybe it is an old question, but I am facing a situation where I have a big structure (64 words) and I want it to be shared with all C files/threads, so is there any way other than using persist variables array method?
anyway I don't want the data to persist, I am using this structure everywhere (reading & writing) so I don't want to keep getting it from the persist data array and loading it back just to modify a bit or two.
I tried to use the header file declaration and the extern keyword with no success.
I hope I am clear enough here.
Thanks in advance.
Re: Global Variables
Post by TomKerekes » Wed Apr 29, 2020 3:22 pm
Hi AlMoutaz,
You can use the 8MByte gather_buffer to store data.
Or you can create data structures within one Thread and pass the address of the data structure to the other Threads through a persist variable. See the examples InterCommunicateThread1.c and InterCommunicateThread2.c
int MyData[300]; // declare some data to share
int *pMyData=MyData; // declare a pointer to the data
	int result=0;
	//give other Threads the address by passing in persist variable 10
	persist.UserData[10] = pMyData;
	while(1){
		Delay_sec(1.0);
		pMyData[299] = result++;
		if(result>10000) result=0;
int *pMyData; // declare a pointer to the data
	int msg;
	pMyData=persist.UserData[10]; //get address from other Thread
	while(1){
		Delay_sec(0.5);
		msg = pMyData[299];
		printf("msg:%d\n", msg);
AlMoutaz_Billah
Post by AlMoutaz_Billah » Wed Apr 29, 2020 7:26 pm
Thank you, Tom, for your fast reply, I will test your solution tomorrow, I hop. :)
