Machine Calibration
CNC_Machines
Machine Calibration
Post by CNC_Machines » Fri Nov 22, 2019 3:36 pm
Greetings,
We currently calibrate our KFlop CNC machines using a set of precision gauges manually, and then opening the ".set" file and typing in the correct values for "axis_offset_x" and "axis_offset_y". I would love to write a C program using a touch probe to write these variables to the set file. Can anyone think of a way to do that?
Thanks!
Scott
Re: Machine Calibration
Post by TomKerekes » Fri Nov 22, 2019 10:17 pm
Hi Scott,
I don't understand this. Please describe in more detail.
From a C Program the Axis Offsets can be changed with:
DoPCFloat(PC_COMM_SET_X,0.0);
This would set the appropriate Axis Offset to make the DRO read 0.0
Here is a great video tutorial by Jeremy Brown. See the description with a link to his code.
CNC_Machines
Post by CNC_Machines » Fri Nov 22, 2019 11:15 pm
Thanks for the video. Let me explain a bit better.
We have a permanent fixture set up on the machine, and use the global coordinator G92 for this fixture. A technician calibrates this fixture location by manually jogging the machine to a known location (feeler gauges and precision ground blocks). The tech will manually type the "axis_offset_x" and "axis_offset_y" offsets into the .set file for the machine. Now every time KMotionCNC is loaded it will pull the correct offsets in.
I am writing a program very similar to the video. I believe that DoPCFloat(PC_COMM_SET_X,0.0) would just rewrite the current G92 value for X, but it would not rewrite the .set file "axis_offset_x". The .set file is very useful because it makes the calibration persistent between rebooting the computer. I would like to only have to calibrate periodically with a procedure like the video, but have it stay permanently.
Does this make sense?
Is there a way to go the opposite direction as well? Is there a function that will return the G92 offset for any given axis?
Thanks!
Scott
Post by TomKerekes » Sat Nov 23, 2019 12:49 am
Hi Scott,
That is correct.
There is an option "Save Always" to make any changes of offsets persistent. Would that work for you?
Otherwise I suppose you could read/modify/write the Settings file from KFLOP using the disk read/write functions like this:
// Example to copy Interpreter's Settings File and make modifications
char * strstr ( const char *, const char * ); // find string function
double NewX = 111.1;  // dummy values to set
double NewY = 222.2;
	FILE *f, *g;
	char s[256];
	f=fopen("c:\\Temp\\MM.set","rt");  // open original file
	if (!f)
		printf("Unable to open file\n");
		return;
	g=fopen("c:\\Temp\\MM2.set","wt");  // open new file to be created
	if (!g)
		fclose(f);
		return;
	while (!feof(f))  // loop through every line of original file
		fgets(s, 255, f);// read a line
		if (strstr(s, "axis_offset_x"))  // modify if x offset
			sprintf(s,"axis_offset_x\t\t\t%g\t\t\tany real number",NewX);
		else if (strstr(s, "axis_offset_y")) // modify if y offset
			sprintf(s,"axis_offset_y\t\t\t%g\t\t\tany real number",NewY);
		fprintf(g, "%s\n",s); // write the original or modified line
	fclose(f);
	fclose(g);
CNC_Machines
Post by CNC_Machines » Mon Nov 25, 2019 4:00 pm
Thanks Tom! That is just what I needed.
Do you know of a function that to return the current offset for an axis? I have been looking through the PC communication functions to try to find one but havent been successful.
CNC_Machines
Post by CNC_Machines » Mon Nov 25, 2019 7:28 pm
I have been working a bit more on this.. I think one of these two functions is what I need.
int GetOriginOffset(double *OriginOffset, int FixtureIndex, int Axis)
if (GetVars(5200+FixtureIndex*20+Axis+1,1,TMP)) return 1; // Download to persist TMP
*OriginOffset=GetUserDataDouble(TMP);
return 0;
int GetAxisOffset(double *AxisOffset, int Axis)
if (GetVars(5200+Axis+11,1,TMP)) return 1; // Download to persist TMP
*AxisOffset=GetUserDataDouble(TMP);
return 0;
Would either of these return the current G92 offset for the requested axis?
Post by TomKerekes » Mon Nov 25, 2019 9:18 pm
Hi Scott,
GetAxisOffset() should return the current G92 offset.
