Post by TomKerekes » Wed Feb 16, 2022 6:46 pm
Please read this.
NOELNOG
Post by NOELNOG » Thu Feb 17, 2022 4:18 pm
Thanks Tom
I was missing "kflopToKMotionCNCFunctions.c" on the head of the program, that's why message box didn't worked, it's working now.
NOELNOG
Post by NOELNOG » Tue Feb 22, 2022 10:12 pm
Hi Tom
i am working with the ATC, my machine is equipped with 8 tool carousel, it is fixed at one end of the machine.
what c. program you suggest me to use and modify for this operations.
thanks
Post by TomKerekes » Tue Feb 22, 2022 10:35 pm
You might look at ARotateToolChanger.c
NOELNOG
Post by NOELNOG » Tue Feb 22, 2022 11:00 pm
I didn't find that file in the set of of c programs, can it be downloaded or can you send it to me please.
Post by TomKerekes » Tue Feb 22, 2022 11:22 pm
Its at:
C:\KMotion435f\C Programs\ToolChanger\Linear4ToolHolders\ARotateToolChanger.c
What Version are you using? Please use KMotion Version 4.35f.
NOELNOG
Post by NOELNOG » Wed Feb 23, 2022 12:03 am
Thnks Tom
i'm using this
Version 4.34 - 08/16/18 ( KFLOP) New* from the dynamotion's website, i ll replace it
NOELNOG
Post by NOELNOG » Thu Feb 24, 2022 6:48 pm
Hi Tom.
I'm trying to use the program, ARotateToolChanger.c assigned to M06, i know that i have to modify some code but i need some help, this is the sequence i want to perform in my machine: move the X and Y axis in rapid near to magazine, then down the Z axis, move X slow to put the tool in magazine, unclamp it, raise Z to clear magazine, rotate magazine to new tool, down Z, clamp tool, move X slow in positive, raise Z to home and go back to run.
also the program should read conditions like clamp sensor, tool position sensor etc, index magazine etc.
my carousel has 8 tools and it's rotated by a 24v dc motor not a stepper, also it has 3 sensors under the disk i suppose they are maybe for gray code or some like that since they are aligned in parallel, also has 2 more sensors in the motor gearbox maybe for index.
please if you have a c. program similar to this or same samples that i can play with i aprecciate it.
regards
Post by TomKerekes » Fri Feb 25, 2022 4:34 pm
You might also look at Linear4ToolHolders Rev 2.c
NOELNOG
Post by NOELNOG » Sat Feb 26, 2022 11:20 pm
Hi Tom
what is the cost for write me an ATC c.program?, this is something that i can't deal with, i am not a programmer.
thanks
