simple 2 axis lathe initial lathe set up
turbothis
Re: simple 2 axis lathe initial lathe set up
Post by turbothis » Mon Dec 11, 2023 9:26 pm
ok, i got the spindle servo mounted and ready to test run in jog mode. i just need the 5v and ground to the encoder
spindle encoder A/B to ch2
spindle Z to A4+ and A4- ( bits 8 and 9? )
i dont really under stand the SpindleOnJog examples as the 3 of them all seem to do something with ClearBit(154); ClearBit(155);
with using DAC output there is no need for any FET bit toggling right?
turbothis
Post by turbothis » Mon Dec 11, 2023 9:41 pm
i think this is the old code for my lathe with spindle servo
#include "MySpindleDefs.h"
int   *css_mode = &persist.UserData[PC_COMM_CSS_MODE];			// Mode 1=Normal RPM mode. 2=CSS
	float speed = *(float *)&persist.UserData[KMVAR];  // value stored is actually a float
	float LastState = persist.UserData[STATEVAR];  // get last state
	persist.UserData[SPEEDVAR] = persist.UserData[KMVAR];  // Always save the last desired speed
	if (LastState==0 || *css_mode == 2)
		// if spindle is off (or CSS mode) and User Changes the speed
		// just save the desired speed
		return 0;
	if (USE_POS_NEG_VOLTAGE)
		Jog(SPINDLEAXIS,speed * FACTOR * LastState);
	printf("Jogging Spindle %f counts/sec\n",speed * FACTOR);
turbothis
Post by turbothis » Mon Dec 11, 2023 9:47 pm
i had 2 buttons
one for turning and one for indexing
the old servo was a 3 phase AC though so it had some phase finding in the main init
now with the brushed DC none of that is needed
turning
	    // A  axis / spindle
	ch2->InputMode=ENCODER_MODE;
	ch2->Vel=300000;
	ch2->Accel=80000;
	ch2->Jerk=150000;
	ch2->P=10;
	ch2->I=0;
	ch2->D=10;
	ch2->FFAccel=0;
	ch2->FFVel=0;
	ch2->MaxI=200;
	ch2->MaxErr=1e+06;
	ch2->MaxOutput=2000;
	ch2->DeadBandGain=1;
	ch2->DeadBandRange=0;
	ch2->InputChan0=2;
	ch2->InputChan1=2;
	ch2->OutputChan0=7;
	ch2->OutputChan1=4;
	ch2->MasterAxis=-1;
	ch2->LimitSwitchNegBit=0;
	ch2->LimitSwitchPosBit=0;
	ch2->SoftLimitPos=1e+30;
	ch2->SoftLimitNeg=-1e+30;
	ch2->InputGain0=-1;
	ch2->InputGain1=1;
	ch2->InputOffset0=0;
	ch2->InputOffset1=0;
	ch2->OutputGain=1;
	ch2->OutputOffset=0;
	ch2->SlaveGain=1;
	ch2->BacklashAmount=0;
	ch2->BacklashRate=0;
	ch2->invDistPerCycle=1;
	ch2->Lead=0;
	ch2->StepperAmplitude=20;
	ch2->iir[0].B0=1;
	ch2->iir[0].B1=0;
	ch2->iir[0].B2=0;
	ch2->iir[0].A1=0;
	ch2->iir[0].A2=0;
	ch2->iir[1].B0=1;
	ch2->iir[1].B1=0;
	ch2->iir[1].B2=0;
	ch2->iir[1].A1=0;
	ch2->iir[1].A2=0;
	ch2->iir[2].B0=1;
	ch2->iir[2].B1=0;
	ch2->iir[2].B2=0;
	ch2->iir[2].A1=0;
	ch2->iir[2].A2=0;
	DefineCoordSystem(1,-1,0,-1);  // define the coordinate system
indexing
	     // A  axis / spindle
	ch2->Vel=100000;
	ch2->Accel=300000;
	ch2->Jerk=3e+06;
	ch2->P=30;
	ch2->I=0.001;
	ch2->D=20;
	ch2->FFAccel=0;
	ch2->FFVel=0;
	ch2->MaxI=200;
	ch2->MaxErr=1e+06;
	ch2->InputChan0=2;
	ch2->InputChan1=2;
	ch2->OutputChan0=7;
	ch2->OutputChan1=4;
	ch2->MasterAxis=-1;
	ch2->InputGain0=-1;
	ch2->InputGain1=1;
	ch2->OutputGain=1;
	ch2->SlaveGain=1;
	ch2->Lead=0;
	ch2->iir[0].B0=1;
	ch2->iir[0].B1=0;
	ch2->iir[0].B2=0;
	ch2->iir[0].A1=0;
	ch2->iir[0].A2=0;
	ch2->iir[1].B0=1;
	ch2->iir[1].B1=0;
	ch2->iir[1].B2=0;
	ch2->iir[1].A1=0;
	ch2->iir[1].A2=0;
	ch2->iir[2].B0=1;
	ch2->iir[2].B1=0;
	ch2->iir[2].B2=0;
	ch2->iir[2].A1=0;
	ch2->iir[2].A2=0;
	    EnableAxis(2);
	 	DefineCoordSystem(1,-1,0,2);  // define the coordinate system
turbothis
Post by turbothis » Mon Dec 11, 2023 10:16 pm
likely jumping the gun but wondering why i can "init" and have encoders read position zero and then when i push either turn or index button i get a new encoder position?
i mean neither index or turn have a set position type command in there right?
turbothis
Post by turbothis » Mon Dec 11, 2023 10:29 pm
jeez i had another code for defs?
#define SPINDLEAXIS 2			// Axis Channel to Jog to rotate Spindle
#define FACTOR (2000/60.0)  	// to convert RPM to counts/sec (counts/rev / 60.0sec)
#define SPINDLECW_BIT 154   	// bit to activate to cause CW rotation
#define SPINDLECCW_BIT 155		// bit to activate to cause CCW rotation
#define SPEEDVAR 99				// global persistant variable to store latest speed
#define STATEVAR 98				// global persistant variable to store latest state (-1=CCW,0=off,1=CW)
#define KMVAR PC_COMM_CSS_S 	// variable KMotionCNC will pass speed parameter (113)
#define USE_POS_NEG_VOLTAGE 1 	// 0 = output Magnitude, 1 = output positive and negative speed
Post by TomKerekes » Tue Dec 12, 2023 1:08 am
No. Its only one bit going into KFLOP JP7 Bit 36
That depends on how your Spindles have an on/off input and +/- 10V to control speed and direction. Some have 2 inputs: on-forward and on-reverse to control direction and 0-10V to control speed
idk what is your Init Program doing? Post it. What are the Position values on the KMotion.exe Axis Screen?
turbothis
Post by turbothis » Tue Dec 12, 2023 5:10 pm
ok,
spindle control
i have a 2000 count encoder with Z pulse
i use a +/- 10V to the drive
1-1 ratio pulley so there is no dirty little numbers there
no relays or on/off required
i want cw and ccw jog and also an A axis indexing
Post by TomKerekes » Tue Dec 12, 2023 6:58 pm
Start here.
turbothis
Post by turbothis » Tue Dec 12, 2023 10:28 pm
well after hours, again i am no closer to understanding where to put C codes or which to use in what configuration with VARS and thread numbers
sadly most of what i search on here just brings up MY previous threads on the same topic on here. lol
Post by TomKerekes » Tue Dec 12, 2023 11:01 pm
So we can help you please put more effort into your responses. Explain what you understand and don't understand, what you have done, and what happened.
I don't think you need any C Code at this point.
Did you do the 3 steps in the link? If so, what happened?
