NOELNOG
Post by NOELNOG » Wed Feb 26, 2025 12:22 am
Hi Tom
I am dealing with a master/slave configuration, i have two servo motors on my gantry, the ch1 is the master and the ch3 would be the salved, but it does not move when jog Y axis, is a slaved motor an other axis? or it works both on one single axis? this is the motor configuration.
regards
// Channel 0, X axis set up
ch0->InputMode = NO_INPUT_MODE;
ch0->OutputMode = DAC_SERVO_MODE;
ch0->Vel = 1600;
ch0->Accel = 10000;
ch0->Jerk = 4e+06;
ch0->P = 0;
ch0->I = 0.01;
ch0->D = 0;
ch0->FFAccel = 0;
ch0->FFVel = 0;
ch0->MaxI = 100;
ch0->MaxErr = 1e+06;
ch0->MaxOutput = 400;
ch0->DeadBandGain = 10;
ch0->DeadBandRange = 0;
ch0->InputChan0 = 0;
ch0->InputChan1 = 0;
ch0->OutputChan0 = 0;
ch0->OutputChan1 = 0;
ch0->MasterAxis = -1;
ch0->LimitSwitchOptions = 0x120;
ch0->LimitSwitchNegBit = 1024;
ch0->LimitSwitchPosBit = 1024;
ch0->SoftLimitPos = 1e+30;
ch0->SoftLimitNeg = -1e+30;
ch0->InputGain0 = 1;
ch0->InputGain1 = 1;
ch0->InputOffset0 = 0;
ch0->InputOffset1 = 0;
ch0->OutputGain = 1;
ch0->OutputOffset = 0;
ch0->SlaveGain = 1;
ch0->BacklashMode = BACKLASH_OFF;
ch0->BacklashAmount = 0;
ch0->BacklashRate = 0;
ch0->invDistPerCycle = 1;
ch0->Lead = 0;
ch0->MaxFollowingError = 1000000000;
ch0->StepperAmplitude = 20;
ch0->iir[0].B0 = 1;
ch0->iir[0].B1 = 0;
ch0->iir[0].B2 = 0;
ch0->iir[0].A1 = 0;
ch0->iir[0].A2 = 0;
ch0->iir[1].B0 = 1;
ch0->iir[1].B1 = 0;
ch0->iir[1].B2 = 0;
ch0->iir[1].A1 = 0;
ch0->iir[1].A2 = 0;
ch0->iir[2].B0 = 0.000769;
ch0->iir[2].B1 = 0.001538;
ch0->iir[2].B2 = 0.000769;
ch0->iir[2].A1 = 1.92076;
ch0->iir[2].A2 = -0.923833;
EnableAxisDest(0, ch0->Dest);
// Channel 1, Y axis set up
ch1->InputMode = NO_INPUT_MODE;
ch1->OutputMode = DAC_SERVO_MODE;
ch1->Vel = 40000;
ch1->Accel = 200000;
ch1->Jerk = 4e+06;
ch1->P = 0;
ch1->I = 0.01;
ch1->D = 0;
ch1->FFAccel = 0;
ch1->FFVel = 0;
ch1->MaxI = 200;
ch1->MaxErr = 1e+06;
ch1->MaxOutput = 200;
ch1->DeadBandGain = 1;
ch1->DeadBandRange = 0;
ch1->InputChan0 = 1;
ch1->InputChan1 = 0;
ch1->OutputChan0 = 1;
ch1->OutputChan1 = 0;
ch1->MasterAxis = -1;
ch1->LimitSwitchOptions = 0x100;
ch1->LimitSwitchNegBit = 0;
ch1->LimitSwitchPosBit = 0;
ch1->SoftLimitPos = 1e+30;
ch1->SoftLimitNeg = -1e+30;
ch1->InputGain0 = 1;
ch1->InputGain1 = 1;
ch1->InputOffset0 = 0;
ch1->InputOffset1 = 0;
ch1->OutputGain = 1;
ch1->OutputOffset = 0;
ch1->SlaveGain = 1;
ch1->BacklashMode = BACKLASH_OFF;
ch1->BacklashAmount = 0;
ch1->BacklashRate = 0;
ch1->invDistPerCycle = 1;
ch1->Lead = 0;
ch1->MaxFollowingError = 1000000000;
ch1->StepperAmplitude = 20;
ch1->iir[0].B0 = 1;
ch1->iir[0].B1 = 0;
ch1->iir[0].B2 = 0;
ch1->iir[0].A1 = 0;
ch1->iir[0].A2 = 0;
ch1->iir[1].B0 = 1;
ch1->iir[1].B1 = 0;
ch1->iir[1].B2 = 0;
ch1->iir[1].A1 = 0;
ch1->iir[1].A2 = 0;
ch1->iir[2].B0 = 0.000769;
ch1->iir[2].B1 = 0.001538;
ch1->iir[2].B2 = 0.000769;
ch1->iir[2].A1 = 1.92076;
ch1->iir[2].A2 = -0.923833;
EnableAxisDest(1, ch1->Dest);
// Channel 2, Z axis set up
ch2->InputMode = NO_INPUT_MODE;
ch2->OutputMode = DAC_SERVO_MODE;
ch2->Vel = 40000;
ch2->Accel = 200000;
ch2->Jerk = 4e+06;
ch2->P = 0;
ch2->I = 0.01;
ch2->D = 0;
ch2->FFAccel = 0;
ch2->FFVel = 0;
ch2->MaxI = 200;
ch2->MaxErr = 1e+06;
ch2->MaxOutput = 200;
ch2->DeadBandGain = 1;
ch2->DeadBandRange = 0;
ch2->InputChan0 = 2;
ch2->InputChan1 = 0;
ch2->OutputChan0 = 2;
ch2->OutputChan1 = 0;
ch2->MasterAxis = -1;
ch2->LimitSwitchOptions = 0x100;
ch2->LimitSwitchNegBit = 0;
ch2->LimitSwitchPosBit = 0;
ch2->SoftLimitPos = 1e+30;
ch2->SoftLimitNeg = -1e+30;
ch2->InputGain0 = 1;
ch2->InputGain1 = 1;
ch2->InputOffset0 = 0;
ch2->InputOffset1 = 0;
ch2->OutputGain = -1;
ch2->OutputOffset = 0;
ch2->SlaveGain = 1;
ch2->BacklashMode = BACKLASH_OFF;
ch2->BacklashAmount = 0;
ch2->BacklashRate = 0;
ch2->invDistPerCycle = 1;
ch2->Lead = 0;
ch2->MaxFollowingError = 1000000000;
ch2->StepperAmplitude = 20;
ch2->iir[0].B0 = 1;
ch2->iir[0].B1 = 0;
ch2->iir[0].B2 = 0;
ch2->iir[0].A1 = 0;
ch2->iir[0].A2 = 0;
ch2->iir[1].B0 = 1;
ch2->iir[1].B1 = 0;
ch2->iir[1].B2 = 0;
ch2->iir[1].A1 = 0;
ch2->iir[1].A2 = 0;
ch2->iir[2].B0 = 1;
ch2->iir[2].B1 = 0;
ch2->iir[2].B2 = 0;
ch2->iir[2].A1 = 0;
ch2->iir[2].A2 = 0;
EnableAxisDest(2, ch2->Dest);
// Channel 3
ch3->InputMode = NO_INPUT_MODE;
ch3->OutputMode = DAC_SERVO_MODE;
ch3->Vel = 40000;
ch3->Accel = 200000;
ch3->Jerk = 4e+06;
ch3->P = 0;
ch3->I = 0.01;
ch3->D = 0;
ch3->FFAccel = 0;
ch3->FFVel = 0;
ch3->MaxI = 100;
ch3->MaxErr = 1e+06;
ch3->MaxOutput = 400;
ch3->DeadBandGain = 1;
ch3->DeadBandRange = 0;
ch3->InputChan0 = 3;
ch3->InputChan1 = 0;
ch3->OutputChan0 = 3;
ch3->OutputChan1 = 0;
ch3->MasterAxis = 1;
ch3->LimitSwitchOptions = 0x120;
ch3->LimitSwitchNegBit = 0;
ch3->LimitSwitchPosBit = 0;
ch3->SoftLimitPos = 1e+30;
ch3->SoftLimitNeg = -1e+30;
ch3->InputGain0 = 1;
ch3->InputGain1 = 1;
ch3->InputOffset0 = 0;
ch3->InputOffset1 = 0;
ch3->OutputGain = 1;
ch3->OutputOffset = 0;
ch3->SlaveGain = 1.03;
ch3->BacklashMode = BACKLASH_OFF;
ch3->BacklashAmount = 0;
ch3->BacklashRate = 0;
ch3->invDistPerCycle = 1;
ch3->Lead = 0;
ch3->MaxFollowingError = 1000000000;
ch3->StepperAmplitude = 20;
ch3->iir[0].B0 = 1;
ch3->iir[0].B1 = 0;
ch3->iir[0].B2 = 0;
ch3->iir[0].A1 = 0;
ch3->iir[0].A2 = 0;
ch3->iir[1].B0 = 1;
ch3->iir[1].B1 = 0;
ch3->iir[1].B2 = 0;
ch3->iir[1].A1 = 0;
ch3->iir[1].A2 = 0;
ch3->iir[2].B0 = 0.000769;
ch3->iir[2].B1 = 0.001538;
ch3->iir[2].B2 = 0.000769;
ch3->iir[2].A1 = 1.92076;
ch3->iir[2].A2 = -0.923833;
EnableAxisDest(3, ch3->Dest);
DefineCoordSystem(0, 1, 2, -1);
Post by TomKerekes » Wed Feb 26, 2025 5:31 am
Hi Noel,
That looks right to me. Except InputMode=NO_INPUT_MODE. How can you have a DAC Servo with no feedback?
The Slave should not be included in the Coordinate System as you have it.
NOELNOG
Post by NOELNOG » Wed Feb 26, 2025 3:23 pm
This is a copy from my workbench pc, i have no motors connected and set NO_INPUT_MODE to be able to watch the readouts but the machine's pc is ENCODER_INPUT_MODE.
I have discovered that the original slaved drive connection on this machine, the encoder signal from the drive was not connected to the original controller, it only close the loop between motor and drive, the rest of the drives they are feeding back to controller, so can i leave the same configuration for kflop? leave the encoder signals from the slaved drive disconnected and set ch3= NO_INPUT_MODE ? otherwise i have to soldering the wires from the drives connector, they left the wires lose :roll:
Post by TomKerekes » Wed Feb 26, 2025 4:22 pm
It’s not clear to me what you are saying. Are you saying the original control just output the same drive command to both motors hoping that the Slave would move the same as the Master without any feedback? You could do that with a C Program. But it seems that wouldn’t work well if there was different friction, cutting forces, binding, etc. I think it would be better to have closed loop servo on both sides.
NOELNOG
Post by NOELNOG » Wed Feb 26, 2025 4:32 pm
Yes the drives master and slave was connected step and dir in parallel both from the same controllers output, buy only the master was feeding back to controller, but yes i will wire both to close loop on master and slave.
NOELNOG
Post by NOELNOG » Wed Apr 16, 2025 7:39 pm
Hi Tom
Can I use absolute encoders with kanalog?, I have a cnc machine equipped with a C axis rotary spindle, but i guess that servo motor uses absolute encoder, the rest of servos uses incremental, no problem but dealing with absolute encoders is new for me, the old controller was feedback from the SSI emulation drive's output, as marked on red in the sheet.
my question is how can i work with that absolute signals?
ENCODEREMUL.pdf
(702.89 KiB) Downloaded 1172 times
Thank you in advance
Post by TomKerekes » Mon Apr 21, 2025 7:16 pm
Hi Noel,
It looks like both absolute and incremental signals are available. Do you need the absolute position? If so you can probably bit-bang the position into KFLOP. (Toggle clock in software while reading data bit). Similar to the SPI V6.c Example. Maybe read it once on power up to synchronize the incremental Position. You would need to research what the data format is. One issue to consider is that SSI uses some idle time to synchronize the data. So once the clocking begins it must be continuous until reading the entire data word. If there is a long enough pause in the clocking the device may reset back to the beginning of the word. So you should do a WaitNextTimeSlice() so that you will be guaranteed to have time to read the entire word without being interrupted.
