simple 2 axis lathe initial lathe set up
Re: simple 2 axis lathe initial lathe set up
Post by TomKerekes » Sat Nov 25, 2023 7:34 pm
Tool Setup | Trajectory Planner | Axis Parameters | cnts/inch have values of 0. Set to some value such as 100. Newer Version will warn you of this.
turbothis
Post by turbothis » Sat Nov 25, 2023 9:54 pm
got it
my OCD does not like values to things i am not using
turbothis
Post by turbothis » Sat Nov 25, 2023 10:24 pm
so i got my dial indicator set up on this to check the count and find that 25,500 get me about a clean .500" travel
maybe a single .001" of variance
with the 2500 count encoder this seems kinda odd on the screw pitch
is there a descent way to measure like a foot of travel?
Post by TomKerekes » Sun Nov 26, 2023 9:04 pm
Gauge blocks?
Post by Moray » Mon Nov 27, 2023 1:01 am
I'm assuming the 25'500 figures is the counts/unit (inch in your case) setting you need to get 1/2"?
From your original/first post, if Z axis is 10mm, and encoder count is 2000, then that should give a resolution of 200counts/mm, now to get 1" travel, it should take 200*25.4, which is 5080 counts/inch.
However, that is if the count is 2000. The 2000 might mean 2000 lines, which would give 8000counts (you get 4 encoder counts per line), or 20320 counts/inch.
But then in your last post, you mention 2500, which would give figures of 6350, or 25'400 counts/inch.
25'400 is probably the magic number that you're looking for.
To check over longer distances, I've often just use the biggest digital caliper I have.
Just remember to move to the start measurement position in the same direction as you will move to do the final measurement position in order to remove as much backlash as possible from the measurements.
I.e. Start at say Z0, move to Z0.5, zero the caliper, them move Z6.5, and check if the carriage has moved 6".
turbothis
Post by turbothis » Mon Nov 27, 2023 6:23 pm
sorry for the confusion.
i am getting all my parts in order of there best use
i have a 12" caliper i will try and get some reading off
thanks!
turbothis
Post by turbothis » Tue Nov 28, 2023 1:13 am
ok, i thought maybe it was a .400 pitch screw ( not 10mmm) and ran with the 25,500 count. this was about .020" too long @ 5" travel
with 25,400 count it is pretty much right on!
turbothis
Post by turbothis » Thu Nov 30, 2023 7:07 pm
what kind of positioning thingy is this?
single ended encoder or some tach like thing?
i am guessing it will not be great for the X axis encoding?
Post by Moray » Thu Nov 30, 2023 10:33 pm
Top section looks like a Tacho, which is of no use for positioning purposes.
turbothis
Post by turbothis » Fri Dec 01, 2023 1:28 am
thats what i was guessing
never touched one before
ill have to get an encoder on this bad boy
thanks
