6 axis wire edm
Re: 6 axis wire edm
Post by TomKerekes » Fri Nov 04, 2022 6:21 pm
Hi Guilherme,
If KFLOP can not communicate to KMotionCNC then you can't have KFLOP send an MDI command to KMotionCNC. You will have to do whatever you need to do entirely within KFLOP.
gui_marchioro
Re: 6 axis wire edm
Post by gui_marchioro » Fri Nov 04, 2022 6:25 pm
It does makes sense.
Thanks Tom.
Sincerely,
Guilherme
gui_marchioro
Re: 6 axis wire edm
Post by gui_marchioro » Sun Nov 06, 2022 12:55 pm
Just to make sure...
The WATCHDOG_DELAY defined in the example WatchdogStatusRequests.c as 5.0 can be set to any desired positive value without problems, right?
Sincerely,
Guilherme
Re: 6 axis wire edm
Post by TomKerekes » Sun Nov 06, 2022 4:27 pm
Hi Guilherme,
Yes it can, but realize that Windows is not a real time operating system. On rare occasions Windows/PC/USB may "freeze" momentarily. That is after all the whole purpose of KFLOP is to provide guaranteed deterministic real-time response so the PC doesn't have to. How long the worst case "freeze" will be depends on many things. So setting to less than around 1 second can run the risk of tripping the watch dog even when things are operating "normally".
Rasta
Re: 6 axis wire edm
Post by Rasta » Wed Jun 07, 2023 8:19 am
hi Tom;
can you please tell me if its possible to edit the IDC_Bplus , IDC_Bminus , buttons so the arrow points in the same direction than the Z axis? instead of pointing left and right?
regards
Mariano
Re: 6 axis wire edm
Post by TomKerekes » Wed Jun 07, 2023 4:08 pm
Hi Mariano,
Yes use the Screen Editor.
