good morning Tom,
problem fixed: now the Spindle is full functional, but only after a modification of FACTOR value into the header MySpindleDefs.h. In particular I had to replace the declaration:
#define FACTOR (1.0/3000.0)
with the new one:
#define FACTOR 0.00033 // (1/3000 = 0.00033)
the first one #define, checked on Console, gave me always zero; can you explain me why?
Happy Easter day
Beppe
S command doesn't work properly
Re: S command doesn't work properly
Hi Beppe,
Congratulations!
I'm not sure.
should work. However:
#define FACTOR (1/3000)
will not work because the first does a floating point division and the 2nd does an integer division which would be zero. Could that be what you really tried?
Congratulations!
I'm not sure.
hi Tom
yes you right: i tryed 1/3000 and not 1.0/3000.0, I am not a C++ user and I didn't know that difference
Many thanks
Beppe
Many thanks
Beppe
