Tom
I open kmotion I/O page right under side when I click led 1 and led 2 on / off I see on the board leds on off. Can ı say board is connecting? or how can I check connecting
I will work about count / inch I think like mach3 per step ( I use metric system) ( when I use ball screw I will back you, first aim stepper motor run) ( I try to understand system)
I have just Kflop board.
if you draw basicly electronic. I can do it. ( after next time I will convert to 24volt machine system not now) I am not engineer, I'm a user.
I add foto I/0 foto of bit 16. This is right?
JP7 pin 4 is same reset or different?.
Could you draw circuit limit switches jp 7 will also apply what is the pin number and simple connection. positive and nagative X Y Z.
I can understand visually.
Best regard..
How can I start up???
Re: How can I start up???
Royal Tech.
YesI open kmotion I/O page right under side when I click led 1 and led 2 on / off I see on the board leds on off. Can ı say board is connecting? or how can I check connecting
It is likely you will have noise problems using 3.3V inputs. But here is a diagram:I have just Kflop board.
I think you forgot the photoI add foto I/0 foto of bit 16. This is right?
Do not use JP7 pin 4 or any #RESET pinJP7 pin 4 is same reset or different?.
JP4 and JP6 each have 16 3.3V inputs with 150ohm pull down resistors. Use those instead of JP7 because to interface to a switch a pull up or pull down resistor is required and JP7 do not have pull down resistors.Could you draw circuit limit switches jp 7 will also apply what is the pin number and simple connection. positive and nagative X Y Z.
Hello Tom
I add drawing about emergency stop. Thats right drawing?
Can I use same drawing for Limits swithc and home swithc?
Can you share Limits pins and home pins? ( will we use JP4 and JP6 pins) and whats the pin numbers?
I forgot to add foto now I added. for bit and Drawing
Many thanks for patience
Royal Tech.
