G codes for 3D printing
Re: G codes for 3D printing
Post by TomKerekes » Sat Dec 15, 2018 8:13 pm
Hi Karl,
The function:
// function to convert Temp C to ADC counts
float TempToADC(float T)
    return  ((-0.000837 * T + 0.170202) * T + 4.565045) * T + 78.452228;  // 3rd order polynomial
receives a temperature and returns what should be the equivalent ADC reading for the temperature.
It is up to you to put in the correct formula for your system. The default formula might act weird above certain Temperatures it was intended for and as Temperature is increased return lower ADC readings.
You might temporarily replace the formula with a simple linear formula like:
    return  T;
In this way you can command ADC counts directly.
Then use that to find what temperature corresponds to what ADC reading over your range of interest, create a table, fit a curve, then enter that formula.
