Help! PWM 0-10V.
Lafayette
Re: Help! PWM 0-10V.
Post by Lafayette » Tue Feb 13, 2018 7:54 pm
Post by Lafayette » Mon Feb 12, 2018 9:21 am
I want to use to adjust the spindle speed
JP6 IO26 Gen Purpose PWM0 out
I want to use to turn the spindle on and off.
JP6 IO27 Gen Purpose LVTTL I/O 3.3V
Lafayette
Post by Lafayette » Tue Feb 13, 2018 7:56 pm
I'm sorry, I was a little mistaken.
Lafayette
Post by Lafayette » Tue Feb 13, 2018 7:59 pm
I will connect the optopar to the flap, and from it I will connect to the servo amplifier at the input of the work permit(S-ON).
Lafayette
Post by Lafayette » Tue Feb 13, 2018 8:00 pm
Pin 26 is connected to the converter that led you higher, it will be controlled by the speed 0-10V.
Post by TomKerekes » Wed Feb 14, 2018 6:59 pm
Sorry I don't understand. Do you have a friend who can communicate better in English?
Please respond to our previous questions and provide the requested information.
CoraDias
Post by CoraDias » Mon Apr 23, 2018 5:39 pm
Hi...If you have a 12V power supply, you don't need rail to rail. An LM 358 or similar works fine if your filter has a fairly low cutoff. Using 16 bit PWM you can easily get the needed resolution. Here's what I've used. PWM freq is 1KHz. 5V input . The pot is to dial in 10V as the top end.
pcb assembly house
Grod45
Post by Grod45 » Thu May 10, 2018 9:53 am
Hey Is it possible to control spindle motor speed with 0-10v DAC by sending analog signal to KFLOP board convereted by DAC while interfacing with Raspberry Pi, your suggestions will be helpful
Post by TomKerekes » Thu May 10, 2018 3:01 pm
Hi Grod45,
Sorry I don’t understand your question. KFLOP itself doesn’t have any Analog inputs. Normally you will need a PC running Windows.
MichaelMet
Contact:
Help PWM 0 10V
Post by MichaelMet » Mon Jun 25, 2018 5:38 am
Will do, I'll see if I can take some pictures as-well.
All I really need is a simple PWM driver, but I can't seem to get the code correct.
Just the pot that sets the duty cycle of a 16khz signal and that output to the fan, no feedback required....
Much simpler than the example here..is there a HEX file for that around?
-Nhilar
Post by TomKerekes » Tue Jun 26, 2018 6:05 pm
Hi Nhilar,
Sorry I don't understand the issue.
You might look at the PWM1KHz.c example for a simple example to set a PWM value.
