Modbus communication with HMI eliminating the PC
ajith
Re: Modbus communication with HMI eliminating the PC
Post by ajith » Sat Jul 09, 2022 4:52 am
Respected sir,
I think there is an option for modbus communication. if it so is it possible to communicate with HMI and access the kflop inputs and output.
what are devices can be connected with kflop via rs232 and rs48?
Post by TomKerekes » Sat Jul 09, 2022 5:11 pm
Yes
Any device that does serial communication. KFLOP itself only has a 3.3V UART. See here.
ajith
Post by ajith » Tue Jul 12, 2022 12:40 pm
Respected sir,
Is it possible to add external start and emergency stop to initiate and stop my G code program?
if it so can you guide me how it is done?
Ajith Arawinth,
Post by TomKerekes » Tue Jul 12, 2022 5:36 pm
See the ExternalButtons.c example
ajith
Post by ajith » Wed Jul 13, 2022 12:07 pm
Respected sir,
I had gone through the program.
In that program they had defined the following variable.
#define FEEDHOLDBIT 46
#define CYCLESTARTBIT 47
#define ESTOP 26
#define HALTBIT 27
#define RESTARTBIT 28
#define ZEROALLBIT 29
After i connect my external pushbutton with the corresponding input as defined in the above whether i need to execute the " ExternalButtons.c " or is it enough to declare the program in any one of the thread in kflop.
Post by TomKerekes » Wed Jul 13, 2022 3:32 pm
Yes it must be compiled, downloaded and executed to do anything.
After it is working it can be merged into your Init C Program's forever loop.
ajith
Post by ajith » Thu Jul 14, 2022 6:33 am
Respected sir,
Is it possible to call the "ExternalButton.c" program directly into my Init C Program's forever loop.
Post by TomKerekes » Thu Jul 14, 2022 3:57 pm
No there can be only one program. But you can call functions in included files.
ajith
Post by ajith » Fri Jul 15, 2022 10:46 am
Respected sir,
can you explain the procedure to establish an rs232 communication between a HMI and Kflop?
Post by TomKerekes » Fri Jul 15, 2022 4:12 pm
See here.
