Error: Invalid buffer times in Trajectry Planner"
Re: Error: Invalid buffer times in Trajectry Planner"
Post by TomKerekes » Wed Mar 16, 2022 12:56 am
That looks like a time stamp shortly after the patch. I installed the patch and I still can't duplicate the problem.
Anything else you might have changed or doing differently that I may not be aware of?
I don't see any tool compensation or offsets so I'm not using any.
You might try a fresh install of Version 4.35f
I suppose it could be a timing thing linked to CPU/PC/USB speed. My i7 W10 system is somewhat old but fairly fast.
Could you try to pair down the GCode to the absolute minimum that still fails?
cwatson1982
Post by cwatson1982 » Wed Mar 16, 2022 1:58 am
There are about 8 other ops in the program. The one right before this calls the tool/offset/spindle speed (it's the same op, just patterned to a different instance of the part, it also doesn't error out weirdly). I can re-post with just that op, make sure it still fails and upload that if it does.
Your old I7 is probably a lot faster than what I am using :)
I reposted the whole program (and saved the error-ing version) with different path and smoothing tolerances and it stopped erroring out.
Post by TomKerekes » Wed Mar 16, 2022 7:08 pm
Strange.
The GCode is a bit segmented in that area but that shouldn't cause an error.
Here the "error" segment shown in red:
Corner Rounding smooths it:
